Company Logo Shop Now
Oil pan gasket
poorhunter
04-19-2014 04:31:08
I am getting ready to put the oil pan back on my 5000, and wanted to know if i would need gasket seal along with/instead of the regular gasket. There are some "gaps" where the timing gear cover and block meet that look like a gasket won"t do by itself. When I took it off, there was gasket seal there already. If I need some, what is the best kind? Thanks
showcrop
04-19-2014 09:32:07
 Re: Oil pan gasket in reply to poorhunter, 04-19-2014 04:31:08
There are a bunch of different gaskets available for those. I was told that there were a lot of tries at making it so that it would not leak. There was a tendency for there to be a little movement between the pan and the block because of the pan being "structural". The 9000 is the same way, I opted for the $9.00 gasket instead of the $90.00 one and put the permatex that comes in the tube on the pan surface. It has been about four years now and no leaks despite some pretty good stress.
Bern
04-19-2014 07:05:18
I like #2 permatex for those joints. You do not need it for the entire length of the pan.
soundguy
04-19-2014 13:44:02
 Re: Oil pan gasket in reply to Bern, 04-19-2014 07:05:18
that and avaition form a gasket are soe of my favs
Bern
04-19-2014 18:31:09
 Re: Oil pan gasket in reply to soundguy, 04-19-2014 13:44:02
The problem with that aviation sealer is that you don't want to be the poor soul who has to take it back off in the future. Any gasket glued on by that stuff needs to be physically ripped in half to get apart. But that's not the worst part. Then you need to scrape the old stuff off!
soundguy
04-19-2014 18:39:37
 Re: Oil pan gasket in reply to Bern, 04-19-2014 18:31:09
someone at one time glued a cork pan gasket onto the underside of the engine on a 660 i was working on. not to the pan itself. so I had to lay there under the darn thing with a razor and gasket scrapper getting the stuff off.
on the plus side. i've never had a leak failure using it.
but yeah. next guy probably cuss ya..
WayneB
04-19-2014 06:47:34
When I did my Ford 4000, I used gasket and non hardening RTV, color was blue. I did not do my oil pan in the shop, I did it in the field, 2 feet from the stump that hit the drain plug and started a leak when I was bush-hoggin in the wild I was clearing for pasture. It sat there for a week while I rounded up the parts. Laid a piece of cardboard under the tractor and went to work. Thats the bad news. Good new is I have no leaks. Our repairs are different. My challenge was the two front bolts with no clearance, that I had to cut off the heads to get them out, because the bolts were too long. Went back in fine with right length bolts. But that did tell me my tractor had received an out-of-frame rebuild. Those long bolts would only go in before the engine was set. Non-hardening RTV and gasket.
Wayne
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: Hiniker 1300 rear window frame looking for one closer to Iowa the better [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
