Company Logo Shop Now
Hole in Hydraulic line from pump to final drive
Robb-PA
03-19-2014 08:06:13
Is there anything behind the plate on the final drive where the hydraulic lines go into. Need to take lines off to braze a hole in the metal line. Can you buy these lines or am I better off having it repaired?
Ultradog MN
03-19-2014 13:37:07
 Re: Hole in Hydraulic line from pump to final drive in reply to Robb-PA, 03-19-2014 08:06:13
Your tractor must either have an SOS transmission or a crash box that does not have Independent PTO as they were the only 3 cylinder 4000s that used the side pump and external lines.
It should not be hard to braze either of those lines though you may have to drain the oil out of the rear end to get it out of the lines before brazing if you do it in place.
There is a 3 bolt flange on the pump and 4 bolt on the rear end. Easy to remove.
Nothing behind them to worry about except I would replace the Orings if you remove it.
I have a good set of lines from a 4000 here if you find you can not repair the one you have.
third party image
Robb-PA
03-19-2014 13:42:02
 Re: Hole in Hydraulic line from pump to final drive in reply to Ultradog MN, 03-19-2014 13:37:07
Ultradog - Thanks alot!! Going to tackle this project this weekend. If I find out they cant be repaired I will post and let you know.
Kurt-NEPA
03-19-2014 11:58:31
Thanks Brian, I wasn't thinking track at all.
Ultradog MN
03-19-2014 13:39:50
 Re: Hole in Hydraulic line from pump to final drive in reply to Kurt-NEPA, 03-19-2014 11:58:31
I think...
Robb meant the double reduction gears on a 4000 and larger tractor.
Brian Allen
03-19-2014 09:11:16
Kurt
Final drives are used to drive the tracks on track driven equipment. This allows the individual clutches and brakes to steer the unit.
Brian
Kurt-NEPA
03-19-2014 08:48:24
Hi Robb,
Welcome to the forum. What tractor are you working on? - that really helps us. Also what do you mean by final drive?
Robb-PA
03-19-2014 09:12:56
 Re: Hole in Hydraulic line from pump to final drive in reply to Kurt-NEPA, 03-19-2014 08:48:24
Sorry. Tractor is a Ford 4000 (1965??) The lines come out of the hydraulic pump, down the right hand side of tractor and go into the rear end (underneath the running boards). The hole is right in the middle of this line.
Today's Featured Article - The Nuts and Bolts of Fasteners - Part 2 - by Curtis Von Fange. In our previous article we discussed capscrews, bolts, and nuts along with their relative hardness and thread sizes. In this segment we will finish up on our fasteners and then work with ways to keep them from loosening up in the field. Capscrews, bolts and nuts are not the only means of holding two parts together. When dealing with thinner metals like sheet tin, a long bolt and ... [Read Article]
Latest Ad: Shaw due all tractor [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
