Company Logo Shop Now
Order Ford 2000 Parts Online
Ford 2000 diesel pushing air out of air intake
Minifarmer
03-10-2014 16:47:44
Recently acquired a 1967 Ford 2000 3 cyl diesel
when engine is running we can feel little air blowing at the air intake stack. No smell it seems
fresh air. What would cause that ?
Thanks in advance
Minifarmer
sotxbill
03-11-2014 17:20:03
 Re: Ford 2000 diesel pushing air out of air intake in reply to Minifarmer, 03-10-2014 16:47:44
check valve adjustment... or stuck or burnt valve.. bad head gasket unlikely..
You can crack the injectors to find which cyl is not doing its work as sounder said. Then look at it.. run compression check if valve adjustment is ok.
soundguy
03-11-2014 16:20:13
while running, use a TOOL to crack each injector line to let it leak. do one at a time. see if one makes less sound / rpm difference than the others.
if you find one that makes a fairly noticeably less difference, concentrate on that jug
Latest Ad: John Deere A 1945 styled [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
