Company Logo Shop Now
Drain plug with cotter pin
Fred Childers
03-06-2014 21:30:40
Sometimes my drain plug with a cotter pin dangling out of it leaks some sort of fluid.
What would/could that fluid be coming from?
Thanks- I am soooooo new to this I now I sound dumb...I'm not. Just afraid I will take something loose that will damage something else......
TimInd
03-07-2014 20:38:43
 Re: Drain plug with cotter pin in reply to Fred Childers, 03-06-2014 21:30:40
I'll add, that my dad would say in the late 1940's that it was good to see a little oil on the floor, since that showed that the main bearing was getting oiled. Those old rope main seals always leaked a little bit.
old
03-07-2014 08:57:15
On most fords like the N series or the X00 or X01 series it could be water from condensation/rain or engine oil or transmission oil or a mix of all 3. Rear main seal on the engine leaking some or transmission seal leaking etc.
Bob
03-06-2014 22:11:31
What are you working with?
Drain holes in the clutch housings of many of these old tractors have a cotter pin in them that jiggles around during tractor operation and thereby keeps the hole open.
In that situation, a engine oil leak at the engine's rear crankshaft seal or transmission oil leaking forward into the clutch housing will find it's way down to the drain hole and "mark" the tractor's territory.
Today, we expect everything to be clean and sanitary, but "back in the day" nobody freaked out about a few drips of oil on the ground/floor every now and then.
NOT sure what you are looking at the has a cotter key/pin in a drain PLUG, although I have seem various machinery with a fill/vent plug with a cotter key through between flats to keep the vent hole open, just like the previously mentioned keys in drain holes.
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
Latest Ad: Armstrong 11.2x24 4 ply new never run,mounted on Allis B or C rim [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
