Bennett French
I have a 1966 Ford 2000, gas, 3 cylinder and I want to replace the ignition system with the Pertronix electronic ignition. The instructions for the electronic system call for a 3.0 ohm coil. I checked the resistance of my coil and it is 1.5 ohms. I bought a 3.0 ohm coil. The instructions for the new coil include a test to determine if there is a resistance wire or ballast resistor in the original configuration. The results of that test (less than 12 volts between the positive terminal of the coil and ground, with the negative terminal of the coil grounded) indicate that there is a resistor of some sort somewhere. Should I try the electronic upgrade to the distributor using my old coil, or should I use the 3.0 ohm coil? If I change the coil, does anyone know how to remove the additional resistance? Thanks.
