Ford 5000 gauge cluster mounting seal
Anonymous-0
I have a 1968 Ford 5000 I just purchased a new gauge cluster for it but I need the mounting seal (I believe that is what it"s called) does any one know where you can get them or something else to use thank you for comments Art
Don't remember there being a gasket behind the instrument cluster. Guess you could make one out of gasket material.
BigWill
The 65-10/68 tractors had nuts moulded in gskt and later used j nuts with gskt loose behind cluster. Its on NH parts site. May be avaible from YT parts.
It is a rubber gasket that slips over the edge of the hole in the cowl where the gauge cluster fits in. It has 4 nuts molded into it (one in each corner) this is how the gauge cluster is fastened to the tractor.
