Company Logo Shop Now
A 850 you don't see very often
FLOLDFORD
11-08-2013 15:11:58
third party image
third party image
third party image
A friend of mine had his 850 kerosene tractor at the Florida Flywheelers show this week. I have never seen one in person. Took a few pics to share. It does have the correct tank and the 3 way valve. Serial number has a K at the end. He is still looking for the correct manifold as the original was broken and not repairable
lonestarjeff
11-18-2013 09:29:37
 Re: A 850 you don't see very often in reply to FLOLDFORD, 11-08-2013 15:11:58
I didn't know there was such a variation in the hundred series....thanks for posting!
Jeff
wayde
11-10-2013 19:07:29
 Re: A 850 you don't see very often in reply to poorhunter, 11-08-2013 15:11:58
freds
11-09-2013 19:48:23
Some of the old JD A's used a gasoline start with some type of distillate fuel after warm up. It was referred to locally as "power fuel". An older neighbor had a hand flywheel start A. Starting, as I recall, was to open compression release valve on each cylinder, start on gas, close valves, warm up engine, switch over to "power fuel". I do not know how it impacted power but I would think the compression ratio was low and each spark plug was required for firing when using the heavy fuel.
Dollar Bill
11-09-2013 13:53:56
John, as I recall, they start up on gas and once they're warmed up, they switch over to kerosene.
The special manifold for them had a built in heat sink to warm the kerosene and make it detonate easier. Dual fuel tractors were more common during the war when gas was rationed. Heating oil was a necessity and more readily available.
Obviously, power was a tad less when running on kerosene as it was somewhat less volatile.
John in La
11-09-2013 13:12:42
Considering Kero is a form of diesel can someone explain this system a little.
I thought the Kero tractors were just that; never knew they ran on gas also.
gatcchelguy
11-09-2013 09:07:49
Don't very often see a X00 series with power steering either.
Fordfarmer
11-09-2013 07:35:16
Thanks for sharing. I've never seen a kerosene tractor of any make or model around here. I bet we all know what's on Sounder's wish list now! :)
soundguy
11-09-2013 13:06:38
 Re: A 850 you don't see very often in reply to Fordfarmer, 11-09-2013 07:35:16
I actually passed up a 641 AN that was for sale from? messicks maybee.. it was listed onthe other board a while back.
with parts tot he vaporizer carb NLA.. i wasn't sure about taking it on as a project, since I like all my machines to run.
Kirk-NJ
11-09-2013 03:25:33
And with the powermaster gear decal too. Very Nice.
Kirk
Dean
11-08-2013 17:08:42
He will need more than luck to find the manifold.
Dean
Texas!
11-08-2013 16:57:05
That tractor was built at the very end of X00 production. The highest serial number that I have heard of is 144875 which a member of this forum owns.
soundguy
11-08-2013 15:24:00
Nice!
Latest Ad: John Deere A 1945 styled [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
