Ford 600 tractor
My Ford 600 tractor is missing a piece of the framework of the 3-point hydraulic lift control lever. I believe that it"s purpose is to help maintain lift control lever position. I have not been able to find it depicted in any manual diagrams for the replacement part number. I would like to replace it. Any help or advice would be greatly appreciated.
Here's the New Holland parts page for the 600 series hydraulic top cover, which includes the parts breakdown for the control handle and the quadrant assembly:
http://partstore.agriculture.newholland.com/us/parts-search.html#epc::mr60173ar1101582
Use the slide control at the bottom to zoom in and then click and drag the picture around to see all of the different parts of it when it's zoomed in. You should be able to see every part fairly well. If the part you're looking for isn't in that picture, then maybe it is something that a previous owner added.
The friction disk {45} in the parts diagram provided by Sean along with the spring {48} is what holds the lift control lever in place.
