Company Logo Shop Now
Order Ford 5000 Parts Online
Ford 5000 PtO
Jim Buckingham
07-25-2013 17:11:31
I have a Frod 5000 (1968 I think). The PTO does not seem to work. Shaft spins but no power. So I was going to start by changing the rear fluid. It has a Farmhand loader (Model 22) on it. It also has one rear remote. My question is, the manual says it takes 36 quarts fo fluid, but that is without a loader. Do I need to add more with the loader to make sure the rear is full and maybe the pressure will come up for the PTO.
Bern
07-25-2013 17:49:35
 Re: Ford 5000 PtO in reply to Jim Buckingham, 07-25-2013 17:11:31
If the loader was empty, you would need more. Since the loader is full, check the oil level in the tractor with the bucket resting on the ground. Oil capacity should be about the same as without a loader if you drain the rear axle and re-fill.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: DEARBORN SIDE DELIVERY RAKE CAN BE REPAIRED AND belly mount MOWER FOR PARTS ONLY.. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
