Company Logo Shop Now
no power, miss, diesel in crankcase
Alstractor
06-10-2013 16:49:06
tractor starts up, runs ok for a bit, the longer it runs the less power it has, seems to be only running on 2 cyls at times, crank case fills with fuel.
do I replace the cav pump? or pump and injectors?
anything else I should look for?
Thanks Al
gatchelguy
06-11-2013 06:49:09
 Re: no power, miss, diesel in crankcase in reply to Alstractor, 06-10-2013 16:49:06
If it has cold start, remove the air cleaner hose and look in the manifold. Should be dry. That manifold heater can leak and fill a crankcase.
alstractor
06-11-2013 07:28:12
 Re: no power, miss, diesel in crankcase in reply to gatchelguy, 06-11-2013 06:49:09
no cold start. dry inside manifold
Brian Allen
06-10-2013 20:05:14
Alstractor
A little more information always helps! It sounds like it is not getting enough fuel.
Checking to make sure you have good fuel flow to the fuel pump is the first thing to find out!
Has the fuel tank, shutoff valve and screen been cleaned lately? Fuel filter(s) been serviced?
Brian
alstractor
06-11-2013 05:36:23
 Re: no power, miss, diesel in crankcase in reply to Brian Allen, 06-10-2013 20:05:14
seems to fill crankcase even while sitting if i dont turn off fuel, when running i think the pump pressure is leaking down thru front pump seal and not feeding all the injectors, is this possible?
RodInNS
06-11-2013 13:46:50
 Re: no power, miss, diesel in crankcase in reply to alstractor, 06-11-2013 05:36:23
Yes, that is possible. Very possible... However, do a drop test on the injectors first to eliminate that before you move to the umbrella seal on the pump shaft.
Rod
RodInNS
06-10-2013 17:52:56
Start it up... then open each injector one at a time. When you find the one that doesn't make it stagger... remove it. Most likely has a bad tip. Really... it would probably be best to have all three injectors serviced.
Rod
showcrop
06-10-2013 17:02:13
If it is a JD running on two cylinders it should make adequate power. If it is a six cylinder two would probably be a little weak. What make and model is Al's tractor?
alstractor
06-10-2013 17:20:08
 Re: no power, miss, diesel in crankcase in reply to showcrop, 06-10-2013 17:02:13
haha sorry guys 1975 ford 4500 ind backhoe loader... 3cyl diesel
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: Hiniker 1300 rear window frame looking for one closer to Iowa the better [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
