RanchhandJ
New User
Hi Folks,
How do you get the back drum brake off a Ford 640? I have read the shop manual and it says to remove the two screws or three spring nuts that attach each brake drum to the axle shaft. I am not seeing any screws or nuts on the backside of the drum. Will they sticking out or are they covered?
I have already removed the retaining clips on the lug threads. I've tried prying the drum a bit and knock it with a rubber mallet and still no luck.
Thanks for any input.
Rick
Rick
