I've searched every link I can find for the answer to this. I'm
sure as soon as it finally sinks in ill have a "well, duh" moment.
My tractor was converted to 12v before me and has run great
until now. Starting problems lead me to replace the coil, plugs
points ,etc. there is a terminal block under the dash that is 12v
on one side 6v on the other. 6v wire goes to the coil. Now the
part I can't get straight; is this a 6v coil? Is the block the
resistor or just voltage reducer? Do I use a 12v coil with
resistor? 6v without a resistor?
