I just installed my newly rebuilt power steering cylinders, and they leak! The rebuilder cut the cylinders open with a pipe cutter to replace the seals, then tig welded them back together carefully to avoid cooking the seals. I installed the cylinders on the back ends and left the front ends loose. I fired up the tractor to make sure I had the lines hooked up properly. When I turned the wheel left, the left cylinder pushed out, as it should. The other side retracted as it should. The right side worked in the proper direction also. I then hooked up the front end of the cylinders and turned the wheel with the front end jacked up. The front wheels turned properly. I then lowered the front end to the ground. With the tractor running I filled the power steering pump reservoir. The left cylinder started leaking fluid past the wiper, making a puddle on the floor. I replaced the cap on the reservoir and found that both cylinders leaked when turning the wheel, and the wheels turned but slowly. What happened? I should mention that I have upgraded to the new style power steering pump with integral reservoir and I had to replace the spring in the pressure relief valve with a weaker one to bring the pressure down from 1200 psi to about 750 psi. It's a bit higher than the recommended 650 but I figured close enough. I also replaced the power steering lines and rebuilt the steering box. The cylinders are leaking when I turn the wheel even though the wheels are not turned to the stop. Any thoughts appreciated. I bought this tractor in July and have been fixing it since then... this was the last thing keeping me from using it.
