Jack L. Massimino Sr.
This message is a reply to an archived post by 36 coupe on May 19, 2012 at 03:28:33.
The original subject was "Re: Electrical problem possible solenoid".
Hi guys, I finally rewired my 601 with a diagram I found on this site but for the life of me can"t find the post. Anyway, I wired it with the original on/off key switch and it is set up for the original push button start switch. The other day before I put the hood back on, I threw the old battery in and hooked the jumper cables to it. I turned on the key and pushed the button. The starter started to turn over which I took as a good sign. I knew it wouldn"t start because that old battery is totaled. It will not take a charge for anything. I put the hood back on and grabbed the battery out of my 65 Chevelle which is a good battery. I hooked it up and now when I hit the starter switch all I get is one click from the solenoid. Then it won"t even click till the battery is unhooked for a few minutes and then rehooked up. There is again power to the battery side of the solenoid but no power to the starter side when I push the button. I was reading in another thread to unhook the wire from the starter switch and ground the wire out and it should turn over if the switch is bad. All I get is the one click. Now I didn"t go get a 4 post solenoid for the diesel and am now wondering if that is the problem or what. What do you guys think? And if someone has a diagram like the ones I found here somewhere that is in English and simple like this one, I would greatly appreciate it if you could post it. My set up is with a one wire alternator and a 4 wire solenoid.
Here is the link for the thread.
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=ford&th=524938
