FarmerBlair
Hi all,
This weekend while mowing grass with my 1958 841 diesel the engine started making some hard knocking/clunking sounds. Looking it over with my machinist neighbor, we came to the conclusion that its a broken crankshaft. By hand, I can pull the crankshaft pulley in and out of the engine about an inch!! It still starts and runs, but you can see the crankshaft pulley whipping in and out of the engine (about an inch or so) on every stroke, which corresponds to the engine noise. The bolts on the pulley are all tight so its not a loose pulley. Any ideas on how this happened or had this happen to you?? I spent big bucks on a complete rebuild on this engine a few years ago. About every moving part was replaced, except the crankshaft. I don"t know if the crank itself was magnafluxed , but probably was since it was reground. Hopefully the engine isn"t completely trashed.
Thanks
Thanks
