Greg Wolodkin
Tisco water pump went in easy, no more leaks.
Spent an hour wailing on the tire bead with a 10-12# tire maul. Maybe made some progress but it was 90F out and after an hour I figured I was done. Made 5 trips around the rim on both sides, but no major movement.
Found a guy locally who unmounted the tire for me, sold me a new tube, cleaned up the inside of the old tire and remounted it on a spare 12x24 rim that I had picked up a few months back. I'll try to patch up the old rim but I think that's a winter job. It looks pretty bad, probably a 4" square area at least that needs to be patched up.
Worked the tractor a little bit with the rake attached. The hydraulic pump seems kind of noisy when lifting. Might just be the tubes vibrating, can't tell yet. Much noiser than the gear pump in the 4000su.
Only leak I see so far is a slight bit of gasoline making a film on the side of the carb bowl. I suspect the carb body or the bowl is slightly bent from the PO either banging on it or overtightening the screws. Will probably pull it and check for flatness, maybe I can carefully level it up with a piece of sandpaper on a thick glass plate. Any advice there? I put things together with the gaskets dry, no permatex, no indian head, no nothing.
All in all pretty pleased to see the machine running and no longer on jack stands.
Greg
Greg
