first I want to say thank you to all who have posted on hundred series overheating issues in the past. I have learned so much from everyone here on the subject.
with that said my 960 is running hot (230 and rising according to the IR therm at cyl head) while running a 5 foot bush hog in thick 3' tall weeds.
first question - is this just too much for this tractor??
second question
after checking the following
radiator - (new style 4 core)
water pump - new
thermostat - new (correctly installed IAW manual)
replaced muffler and manifold elbow with correct size
fan shroud - got one now
flushed cooling systems with vinegar (thanks old)
timing set with timing light
new coil
new points & condenser
set timing again
compression is acceptable with in 5 psi on all cyl
what else is there???
-Paul
second question
water pump - new
new coil
set timing again
-Paul
