Craig Kruse
Hi Guys, I could use a little help. My data plate on my 3400 says I should have an 8 speed transmission. I think it's been changed out someewhere along the line but not sure. Best I can tell I have four forward speeds and four reverse speeds and if I understand the book this is a shuttle type transmission refered to as manual reversing. I have the following based on my best guess:
In Low (forward) I have what I believe to be 1st gear in the upper right and 2nd gear in the upper left. I have Reverse below each of these.
In High I have 3rd gear in the upper right and 4th in the upper left with reverse below each of these. Does this sound right
I was looking to find a new shift pattern decal and can't find anything that matches. any help would be appreciated. :?:
