Anonymous-0
I am replacing the tie rods. On both sides at the location of the width adjustment clamp, the shaft and tube are rusted tight together. On the left side, which is just 2 pieces I only needed to take them apart to get the clamp off. After lots of soaking and pounding I finally just cut to old tie rod to get the clamp off. On the right side, I either I got the inner tie rod end off with no problem but I cannot get the outer tie rod shaft apart from the tube. I need the tube in order to replace the right side tie rod ends or I need a new tube. It has been soaking but I may need a new tube. On New Hollands site I believe it is part number C7NN3B624B which on part sites is 19.15" long. My tube is only 15.75" long. Am I looking at the wrong part number? All the new tie rod ends from this site match the old ones.
