Order Ford NAA Parts Online
Identifying Jubilee backhoe
Timothy Masters
03-18-1999 04:35:45
Is there a way I can tell the maker of the backhoe on my Jubilee? This site sells a manual for a Wagner, but it's $60 and I don't want to buy it if it's the wrong one. I see a lot of references to a Sherman hoe in these messages. There's a barely legible nameplate on the control box that says something like "Gone Automatic Machinery, Vermont." Does this help? There is nothing I can find on the hoe itself. Thanks!
Tim
RICK
03-20-1999 17:33:37
 Re: identifying Jubilee backhoe in reply to Timothy Masters, 03-18-1999 04:35:45
Just read your earlier post below. Sounds like you have the exact same thing as mine. Its a Sherman model 54C if it is indeed the same. Mine has a tag riveted on it. Big pump mounted on the power take off? Do you have the Sherman O/U transmission also? Mine leaks adequately to remind me it is 46 years old an needs to be handled gently.
RICK
03-20-1999 17:25:35
The 9N,2N,8N Newsletter has copies of the manuals for Sherman hoes made by Wain-roy.
I got one for mine for a coupla bucks worth of stamps rather than $60. Exploded parts pictures and operating instructions.
Timothy Masters
03-23-1999 08:59:51
 Re: Re: identifying Jubilee backhoe in reply to RICK, 03-20-1999 17:25:35
Thanks for the info that the "9N,2N,8N newsletter has copies of the manuals for Sherman hoes." Please excuse a dumb question, but where can I find this newsletter? I am new here. Thanks!
Tim
Chris
03-18-1999 08:17:29
My Sherman has a large plate on the arm that says Sherman in large block letters(Plat aprox. 3x12)A picture would be worth a thousand words in this case. I will see if I can come up with one of my hoe and scan it and send it to you if you send me your email address.My wagner loader has a plate on the frame under the control valves saying it was built in Minneapolis or St. Paul as I remember. I will look and let you know if I am wrong.I am not sure where Sherman was butlt and would like to know.
I can't honestly say that I can identify any of the other mfgs. by sight . I have seen other hoes and the differences visually were from slight to "thats a backhoe?" Hope to hear from you. Chris christian@seanet.com
Ken Burstall
03-18-1999 08:55:17
 Re: Re: identifying Jubilee backhoe in reply to Chris, 03-18-1999 08:17:29
You will more than likely find that most of the backhoes were really manufactured by Wein-Roy located in Hubberdson Mass. They did 90% and others put their name on it such as Ford, Sherman, Lester
Timothy Masters
03-19-1999 03:42:31
 Re: Re: Re: identifying Jubilee backhoe in reply to Ken Burstall, 03-18-1999 08:55:17
Ken - Thanks for the Wein-Roy info. That's interesting, but my real goal in determining the make is to be able to purchase the correct manual (no small undertaking at $60!) Do you think that the Wagner manual sold on this site would be appropriate?
Tim
Chris
03-18-1999 17:52:05
Thanks for the info! Do you know any more abbt. the company? Are they still around?
Ken Burstall
03-19-1999 12:27:35
 Re: Re: Re: Re: identifying Jubilee backhoe in reply to Chris , 03-18-1999 17:52:05
Yes the company is still around. They are locaed in Hubberdston Mass. I think the area code is 978. Don't know to much more about the company but I have have 3 backhoes on various tractors I have rebuilt. All of them were as strong (if not stronger) than the neighboors 916 turbo and another friends 924 extendahoe.
Chris
03-19-1999 17:20:40
 Re: Re: Re: Re: Re: identifying Jubilee backhoe in reply to Ken Burstall, 03-19-1999 12:27:35
Did they build a truck mounted rig called the Hoptoe? My uncle had one of them when I was a kid.He could do most anything with that rig!
