AlanBarrett
Where can one buy just the starter drive? There was a bad spot on the ring gear for a few years. The clutch finally went out so my bro-in-law replaced the clutch and had new ring gear installed. Soon the starter started then same thing again. When trying to crank, the starter would grind. Eventually it would grab and start. I purchased another starter from local New Holland dealer. Pulled the old starter and inspected the ring gear. The area was about an 1/8, or less, of the overall diameter. What would cause this? Could the damaged area be cleaned and beveled? The starter motor is ok, drive is eaten up.
