Hi All, The lift on my 65, 3000 has been having times lately when it refuses to pick up. This is during use when everything is warm. If I just wait and work the lever it will eventually start working again. Has been around a year since I put a cover kit in and cleaned the filter and new oil. After it picks all the way up I sometimes hear a knocking. Screwdriver in the ear indicates the sound is in the pump. Sounds like a cylinder valve out of adjustment. Noise stops when I let the lever down a little. You can see the drop of oil on the pipe plug where I cracked to bleed, no air, no bubbles, just oil.
I've seen discussed here that more than one pump was used. So the question is which pump is this, so that I might order an overhaul kit?
Thanks .. Matt
Thanks .. Matt
