Anonymous-0
I have a Ford 600 that wont start. When I pull the hose off the air filter side of the carburator a fair amount of gas pours out. I am no mechanic but I am assuming this is not supposed to happen. Thinking the float may be sticking I pulled the carb and cleaned it but I still have the same problem. Any Ideas?? I think I have more problems as well. On a side note I am not getting any spark. I am thinking the coil may be bad but could a bad regulator cause this? If a damn mouse that nested in it through out the winter chewed through a wire then I'm really screwed. Thanks in advance for your help.
