deerefanatic
Ok.... I'm pulling my hair out on this.... Close to $2k later, this stupid thing wont start. I think my I&T manual is leading me astray. All the tractor will do is pop and backfire, or now at least start, struggle on what sounds like 2 cylinders, and die.
Block & head all checked out. Bored .030 over, full valve job. Crank turned. All new bearings, pistons, rings & gaskets. Brand new zenith replacement carburetor since the holley wanted to pour gas all over the shop floor and was one of the models you can't get a rebuild for, brand new ford clutch, pressure plate, pilot and throwout bearing, new points, condensor, cap and pertronix flamethrower coil. New Autolite 405 plugs gapped to .060 to take advantage of the hi voltage coil.
I&T manual says to set motor at 0 degrees TDC compression. Align rotor with #1 cylinder terminal of cap, then install into drive housing. Rotate base until breaker points just begin to open. Doing this means all the motor will do is pop and sputter. I've tried installing the distributor in all different positions and nothing works well. Right now, it will at least start and struggle on 2 cylinders for a bit and then die... The distributor is installed 2 teeth "advanced" from the way the I&T book says.
Any ideas? I'm about ready to push this thing on a long roll off a tall cliff.... I do mechanics for a living, but there's a reason why if it's a gas I won't let it in the doors of the shop. Unfortunately the ladies like this thing and wouldn't let me sell it to get a nice diesel skid steer, so I was over-ruled! LOL
