This message is a reply to an archived post by Greg Wolodkin on February 13, 2011 at 13:10:28.<br>The original subject was "Re: wiring schematic for Ford 4400 Ind. Diesel".<br><br>
This wire goes to the starter.
This wire goes to the solenoid.
Where on them? My diesel 4000SU starter-mounted solenoid has two terminals and a spade connector - 3 connections in all. So "goes to solenoid" means nothing to me. There is a ground terminal on the starter and an insulated strap from inside the starter that goes to one terminal on the solenoid. So "goes to the starter" also tells me nothing.
I've found starter wiring diagrams, but none of them shows specific connections either, including the one found right here.
I'm having to wire from scratch. I have 2 heavy red wires to the alternator and (apparently) to the starter switch. I have a lighter yellow wire from the starter switch. I have two battery cables.
I assume the negative cable goes to the ground post on the starter, but haven't a clue about the rest.
Any help out there about where to put what?
I'm having this problem with both diagrams and descriptions.Big battery cable goes right to the starter. On that same lug there should be another wire which heads back to the key switch via the regulator. This is the "B+" or brown wire. May be different on newer models with an alternator instead of a generator, but on mine, it's really two wires, both brown, from starter to regulator and from regulator to key switch.
When you turn the key to engage the starter, connection is made from this brown B+ wire to the neutral safety switch (white wire with yellow stripe). This is a switch in the transmission that only closes when the transmission is in neutral. This means the tractor won't start unless it's in neutral (more on this later).
The wire from the other side of the neutral safety switch (white with red stripe) heads to the solenoid and gets the tractor turning over...
