I just installed a new transmission starter switch for the Ford 651 tractor. I am assuming it is installed right. All I did was unbolt the shifter, carefully remove woodruff key and spring, remove the trans. cover, loosen the nut on the switch, remove old switch, install new switch and gasket, and bolt everything back up. I previously installed a new magnetic solenoid switch thinking that was the problem. I wired it just like the old one was on there when it was working fine before. Still nothing! I had a spare universal push button start switch laying around and bolted it to the dash and wired it up (according to attached diagram).....it starts the tractor fine, however I want the orginal to work.
Please see attached diagram and tell me what I am doing wrong. I have no clue. I checked for power to the wire going to the trans. push button switch, and have nothing. I"M LOST!!!!
Also, not mentioned on the attached diagram is an on/off key switch for the ignition points. I turn it on to run the tractor and off to kill the engine. It works fine when I use the temp. start button.
The new switch I installed is doing NOTHING! Yes, I did put the tractor in neutral...haha
