PeteTheRookie
Finally got this to the point I could top off the hydro fluid and test the back hoe.
Hoe still has other unresolved issues to fix but is back in "workable" condition.
Replaced 5 of the 59" hoses part nbr D8nnd558ea key nbr 1 on the 753 series back hoe parts diagram on New Holland site. The 6 one I had replaced a few months ago when it split.
Had to use dremel to cut off 2 pieces of very sharp metal left from "something" that has been cut out of the back of the hoe frame area where all the hoses exit to the swing arm. One was right on the bottom of frame where the hoses exit, 1" long, by 1/2" high by 1/8 thick" jagged "shark fin" sticking up. Shiny from metal flex hose sheathing rubbing on it.
Other issue I have temporarily resolved with a homemade hose hold down clamp is where the 4 hoses exit swing arm and enter hoe.
That clamp is MIA and I made a temporary one out of 1" pvc flex pipe.
Still need to replace just about every other hose on the back hoe
And need to fix the MIA swing arm pin bushing.
I should probably be looking for a used swing arm as this one is beat to crap, welded all over the place. Bottom pin appears to be welded in place.
Pete
Some pics of replaced hoses
Pete
