I have a 1974 Ford 4000 and have had no major
problems with it. Today i went out to drag the
road and pushed in the clutch and started the tractor and cant get it to shift into any gear.
High or load speed all i get is grinding in each
position. I read in my trusty IT shop Manuel that
there is a clutch release lever inside that is controlled by the clutch release lever that
connects by a clevis to the pedal and i adjusted
that to the tightest position and no go still
grinding. It was working fine when i parked it
several weeks ago, and has had the same amount of
play in it for as long as i can remember... had it
8 years. Whats wrong with it and what do i do to
try to fix it. My assumption is that the clucth
release is not functioning do i have to split the
case to fix this.. I am a not all that mechanically inclined almost 50 year old woman
HELP !!!
HELP !!!
