Company Logo (800) 853-2651 Shop Now
Order Ford 600 Parts Online
Ford 3600 gas wiring diagram
Dale Cook
07-01-2011 08:19:54
Need help with the wiring for instrument panel on a 1980 Ford tractor. I can not get the heat gauge to work. Any help will be appreciated!!
Ultradog MN
07-01-2011 14:21:06
 Re: Ford 3600 gas wiring diagram in reply to Dale Cook, 07-01-2011 08:19:54
Photobucket reduces the size of the photo so perhaps this one is not clear enough for you.
If you send me an email I will send you the original of this one. You can blow it up about 4 times this big.
ultradogmn@yahoo.com
third party image
RodInNS
07-01-2011 08:53:32
Pull the wire off the temp sender and ground it securely. Turn the key on and watch the gauge. If it immediately pegs in the red the gauge and wire circuit are good. Replace the sender with the CORRECT one for that cluster.
If the gauge doesn't sweep, pull the cluster back a bit and find the wire that goes from the temp gauge to the sender and make a jumper wire to ground the gauge on the sender circuit. At the same time ensure that 12V is available to the other side of the gauge... You will notice that this wire will be joined in parallel with a similar wire feeding power to the fuel gauge. Obviously if there isn't power to the gauge(s), you need to trace that back and find the problem. There is also an inline fues in the rats nest above the fuel tank. This is for the cluster power supply...
So if you have power and the guage doesn't sweep when grounded, you have a bad gauge. if it does sweep when grounded at the gauge, you have a bad sender wire.
Rod
berky
07-01-2011 08:41:59
Check the ohms of the temperature sending unit as it may be bad. Cold it should read around 400-600 ohms, when at operating temp should be around 50 ohms. Could also be a bad wire from the temp sending unit.
JMOR
07-01-2011 08:34:29
 Re: Ford 3600 gas wiring diagram in reply to kjrtractors, 07-01-2011 08:19:54
Quoting Removed, click Modern View to seeI expect that the IVR/stabilizer supplies both the fuel gauge & the temp gauge as it does on thousand series tractors, so a clue may be in the answer to the question, "does your fuel gauge work?"
Today's Featured Article - What Price Enthusiasm? - by Anthony West. Quite frankly, for some time now restorers like myself have become more and more concerned about the rapid increase in the prices of old farm machines here in England. There is now a growing market for "As found" machines. Which as machines get rarer, has found the birth of a new industry....one of the "procurement agent". These agents appropriate as much old machinery as possible then inflate prices at auctions. So at what price enthiusiasm? We are now seeing poor machines which 3 years ago ma ... [Read Article]
Latest Ad: 4- D6 cat dozers and accessories [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
