PeteTheRookie
Dam, just had to go after the big granite rock that broke out of a ledge next to the driveway!
Extended hoe out, just start to claw down on it and curl in the bucket and POP. Fluid sprayed all over.
So there I was stuck with the hoe fulled extended across the driveway. No other way to get cars in/out.
Got oil pan under dumping fluid.
Took chains and hooked them in the cross holes in the ends of the stabilizers. Managed to push hoe up by retracting boom and curling in bucket. Then was able to hold it up by lowering stabilizers until chains tightened up.
Had to drive it up over nice white stone driveway dumping hydro fluid.
Its parked on its bed of wood chips, (black to hide all the leaks).
I suppose I need to change hose ASAP.
Anyone got the part nbr I need or can I just go with a off the shelf high pressure hose?
Pete
Pete
