On Saturday, hooked up the brush hog to a new addition to the barn where I work part-time, Ford 3930. Was just going to work an hour or so cutting a smallish area (less than an acre) that was SERIOUSLY overgrown for horse trailer parking. There was a horse show on Sunday. Could have baled the grass, it was so thick.
Anyway, after I got most of it cleared, making multiple passes to chop of the piles, I looked back and the hog was skewed sideways, hanging on by one lower pin. The top link had also unscrewed. Wow. Found that the link arm ball had popped out of the link arm. It's a Cat II hitch where the ball is NOT fixed in the link arm. It's removable and held in place by a spring clip. Now, for the ball to come out means that the linch pin came out of the pin on the brush hog, the link arm separated from the hog (to be expected without a linch pin), the ball had to rotate to one perfect position to come out of the link arm AND the spring clip had to open. (The spring clip was closed when I got off the tractor). A perfect storm of sorts. Not sure when it happened as the top link probably kept it somewhat straight until it unscrewed.
Called around Tractor Supply didn't have one and the one sure place that did (within 4 miles of the farm) had closed 15 minutes earlier. Would not normally be a crisis (get a new ball on Monday) but the problem was that they needed the tractor to drag the arenas on Sunday.
Spent a couple of hours with a few people walking the field, kicking at the piles, got a metal detector and spent a couple of hours with that. Finally decided to cobble together a bushing for the link arm so they could use the drag. Called this AM, it's a $5 part. Gonna buy more than one, that's for sure. Guy on the phone suggested that we remove the ball when we're not using the 3 pt. Guess it happens a lot.
I figure that once we have the spare balls, I'll walk right out to the field and step on the one that was lost. :lol:
