3000 Rocker Arms
Rod9865
I found a bad intake rocker arm while adjusting the valves. The intake and exhaust rockers look the same but have different part numbers. Also the intake rocker is quite a bit more expensive than the exhaust. It has me wondering if someone replaced the rockers and used all intakes or all exhaust when they replaced them. Any help with this will be greatly appreciated.
Rodney
I got a rocker setup if you are interested off a donor tractor.
Email is open
Vito
Thanks for the reply. I went ahead and ordered a intake rocker. I looked again at them last night and the ones on the tractor are the same for the intake and exhaust. My tractor is a 73 model and maybe they changed to different rockers for intake and exhaust in newer models. I guess I will find out when the new one comes in.
Thanks,
Rodney
