3 point wood splitter to 7700 hydraulics help
bluesman7700
New User
I had an older kubota that had a hydraulic switch installed to switch between loader and rear remote for wood splitter, traded in tractor, kept the splitter, what is the correct way to connect to the 7700.
Do i have to bungy a lever up or down.
The splitter has its own in and out valve mounted on the spitter.
Can i use that confusing 3rd remote some how?
No, can't use the Load Monitor couplers. They only
work with a LM cylinder.
Just plug your hoses in, bungie your lever, and see
if the cylinder moves the right direction when you
move the lever on the splitter. If not, bungie in
the other direction. (or swap hoses)
