3400 hydraulic pump questions
oldsamdog
New User
Bear with me here I'm green when it comes to hydraulics here. From what I've been told my pump cracking might be due to a relief valve failure. I got a book on it and I see each of the cylinders has a circuit relief valve and then there is a system relief valve before all of them on the control valve. Is the system relief valve a backup if the others fail or am I way off here? Also could I put a pressure relief valve inline between the pump and control valve until I figure out which one is bad? What psi should I get?
