replaced the leaking brake boots on this 4610, now i cant find the check plug, seems i run into this on every ford tractor i help work on. i can not find a square headed pipe plug on the hyd res. there is a flat head slotted bolt behind the rear support of the RH foot plate. it was reasonably loose when i put a screw driver on it and it would never get any looser, and it will not tighten up. it will also not just pull out, like if it was striped completly out. i know there is a bolt on that side somwhere that holds a pipe on the inside and will drop if you take the bolt loose. i have the pictures of the plug in question, i you have pics of the right plug that would help. on another 6610 i worked on the plug was at the rear above the pto, there is nothing there on this tractor. i am at a loss. thnaks for any help.
