Hello. Working on a friends 3000. It is a three cyl Diesel with CAV injector pump. The tractor started running badly with white smoke / not pulling at summers end and it was parked. Over the fall, the exhaust stack was left off and small amount of water got in. We got it all dried out, changed oil, etc..., did not find any cracks and motor was not frozen. But, it would only barely idle after pull starting and still puffing lots of white smoke.
He had never serviced injectors so we replaced them and flushed and filled the unit with fresh diesel. Changed fuel filter, bled it, the pump, and we are getting fuel to the injectors. Then found the air filter had also got some water in the oil and the draft tube was clogged. Cleaned all this out and the tractor will now start but will not rev or hold an idle for more than about 5-10 seconds.
Weird part is that if you let it set a couple of minutes, it will start and idle normally and sound like it is ok (but will not rev up), then slowly idle down and die like it is running out of fuel again. You can repeat the wait, start, die process over an over, and if you hit the intake with start fluid it will keep running so we are pretty sure its a fuel delivery issue.
So what next? Could the tranfer pump on the CAV be bad? Should we just replace the injector pump? I don't have a way to do a compression test on this engine but it seems to start and run easily initially, just not for long.
BTW, we had a terrible time getting the old injectors out but then we purchased a 17lb slide hammer from a local cheap tool supplier, drilled out the screw end of the puller and fit the 5/16 24 bolt (that also fits the injector return hole), and used a grade-8 bolt in the puller. This pulled the factory injectors in three strokes!
I apprceiate anyones time for next diagnostic or repair steps. I am pretty handy wuth engines and am wondering if I could kit this pump myself or if the $600 exchange is the way to go (if needed).
Thanks... Steve
Thanks... Steve
