NoBite
I have a Ford 1900 and an overheating issue. Used tractor yesterday for various tasks for about 3 hours. As I was finishing up bush-hogging I started to smell something like a burning wood smell. Sort of like years ago when I had a word burning set. Very shortly after noticing that smell, the temp gauge on the Ford went from just above cool to hot and tractor shut down. After letting it set a bit, I carefully released the pressure on radiator cap. Full of fluid, so I didn't spring a leak there. Checked oil level. Fine, if a bit dark. Let tractor sit for a couple of hours. Went back to it and it started right up. I headed back to the barn, stopping for about ten minutes at the manure pile to rearrange the pile. The temp gauge started moving again. By the time I got the Ford into the barn, it was hot again.
I am no mechanic (obviously). What sort of possible causes for this issue come to your mind? Thanks for the help, guys.
