So I'm finally starting to get into my 4500 SOS to try and make the tranny work nice. The main problem I have with it is that the DDC speeds are intermittent. They will work better when the tractor is cold, When they work they are solid and strong, but sometimes (well, most times) they just don't work. I'm not convinced my DDC is bad because the way that its intermittent and not really "slipping" per say. It's more like they just don't engage, or when they do they will just dis-engage for no apperant reason. Maybe I'm just grasping because I don't want to split the tractor being that its a TLB with a cab it would be extra fun.
So to start off, I cleaned out the pickup screen, had some crud, but not horrible. Next I pulled Servo 1 and the large o-ring looks, well like its 40 years old. It's all there, but really loose on the servo, and the edges are all square and scored. Basically doesn't look like it would seal all that well.
My question is, With the symptoms I've described, could it be that Servo 1 is not releasing properly, thus not pressurizing the DDC all the time?
My plan is to replace all the servo o-rings, change the filter, adjust the bands and hope for the best. I think I also had the wrong fluid in there. I had 303 fluid Is there a huge difference between 303 and 134D?
Thanks,
Jim
Thanks,
Jim
