801 powermaster 12 volt conversion
Garycw
New User
I recently acquired a 801 powermaster with a 12 volt
conversion. However all the wires have been bronen off
alternator just above alternator plug. Can anyone advise
where these 3 wires need to be connected?
Under that plug is #1 and @2 #1 goes to the ignition switch and #2 to the big post on the alternator. Bob posted his picture just the other day on this or the N series forum
keep in mind the one ( #1 ) that goes to the ignition switch needs to go thru a 194 traielr marker lamp.
soundguy
Thanks for wiring diagram.
Also my steering wheel on 841 has fallen apart leaving just a wire ring. Any sugestions on where to search for replacement?
ford steering wheels for the 8n and up fit and are cheap and easy to find.
here, tsc, dealer.. etc.
soundguy
Thanks for the diagram. My altenator has a plug on top(2) wires and terminal on side. I assume in the diagram terminal 2/s plug wire is closest to side terminal which I assume is "batt. " after connecting batt & 2/s together can it be ran directly to battery positive terminal?also can the plug labeled 1/f go through warning light then to one side of key switch or somewhere else. Sorry for all the questions but I"m having trouble tracing wires & termination points
