cgregory67
New User
Experienced mechanic here but a little stumped. My Ford 1973 3 cyl gas tractor began stalling and only idles with choke full on. When she cools down it runs full power until engine heats up again.
Ignitiona system fine, fuel clean, fuel filter good. Had myself a can of butane in the tool box and used that as a starting aid when the problem occurred and engine ran. So diagnosis is confirmed fuel starvation problem.
Step 1 removed carb, cranked engine and observed fuel pumping out line.
Step 2 dismantled carb, accelerator piston thingy seemed to be sticking, cleaned up. Float and needle seemed to be free, checked jets, and blew air through passages, reassembled.
Step 3 Ran the Tractor for about an hour moving some gravel and starvation problem re-occured.
Step 4 Retraced all fuel lines, nothing touching block or appearance of vapor lock condition.
Step 5 Scratch my head and post here, what do you all think? I have seen mechanical fuel pumps with cracked diaphragms do similar things in older cars. Not sure if the fuel pump has that same design on a Tractor. Another thought might be float needle sticking, any advice welcomed.
Thanks in Advance
Thanks in Advance
