tigercreek
Rebuilt my injector pump (another post - another story) - waiting on one small piston that should arrive today. Hoping to finally verify the motor.
I have found that I can't trust anything done by the previous owner of this tractor. Right now I'm just trying to get the motor running/checked so I can swap it to my 62 2000.
This is the 62 4000 172 diesel with a SOS tranny
Repaired the starter.
Repaired the alternator.
Replaced cables with 1ga.
Replaced all other ignition wires with 10ga.
The cables were getting hot before the pump rebuild (haven't checked the again). I am questioning the solenoid (everything else was bad!). Not sure if it is the "right" one and it came to me mounted to the sheet metal - don't think that's a good ground.
If I replace the solenoid would I use a BWD #S103?
Where was this solenoid originally mounted?
