Have a 53 jubilee that the hyd. do not respond well. I have a bush hog attached to it at this time and when trying to get to a proper level it is slow to respond. It will raise it all the way up and it goes all the way down but it hard to get it any were in between the two positions. The hyd. control travels a lot with no response from the lift. I am have trouble explaining whats going on with it. When I first started to bush hog today the hyd. would not work at all. It was in the down position and the fluid checked low in that position so i added hyd. fluid to the full mark. It still would not work then. But i waited a min. or two with it running and it final raised up. But was jerky, that went away after some time. The hyd. pump does not have the flow control on the rear of the pump. Not sure if it was replaced at some time or what. If someone can give me any advise it would be a great help.
Thanks,
Keith
Thanks,
Keith
