I'm helping my landlord with a 65-75 Ford 4000 tractor.
He has no manual, little cash, and is not internet savvy.
I have no experience with tractors.
I've found some diagrams on the CNH parts site, so I can ID the parts, thanks to this forum.
The story:
First the lift didn't work. We pulled the cover, and the control valve was stuck. Also the control valve link and turnbuckle were loose from the valve(#25 & 26 on the Lift cylinder page). After removing the valve and cleaning it, we reassembled it all.
First it didn't work. Then I pulled the pipe plug to reach the check valve. It's seamed stuck. I played with the check valve spring housing (#43 on the lift cover page) while the engine was running, and got doused with oil. Shut it down, replaced the plug and restarted. The lift worked fine.
Next day he went to use it and no lift again. He pulled it apart again (with out me) and said the turn buckle/link was loose again.
So, I'm going to disassemble the lift cover and clean it all good, the reassemble. I'll also try seating the ball on the check valve.
When I reassemble I want to adjust everything, as I thing something is wrong. The link/turnbuckle for the control valve shouldn't be coming loose.
I think the quadrant not having a lower stop is part of it, but I still don't think it should come loose like it does.
Again, he doesn't have any manuals, nor the money to spend on any.
I've looked and not had any luck finding an adjustment procedure;.
The story:
