950 spindle bushings
00
New User
I have a ford 950 w/ adjustable wide front end and i need spindle bushings for the front end both sides.Are they the same as the 900?Thanks
Your 950 is a 900. 900 designates the series and 950 the model. The five designates a five speed transmission. Check out the parts on the site, they offer soindle bushings. See the link below. Also, for more info on your tractor visit www.oldfordtractors.com. Hope this helps.
Parts
Sorry, i forgot to add that the 950 is a high crop.Will this make any difference?Thanks
00:
Are you sure that your 950 is a high crop? If so, it should use the same spindle bushings.
Dean
Ya im sure it's a high crop, it has the bull gear to drop the axle in the rear.Thanks FOR THE INFO.
Thought so, 00.
9xx tractors are "row crop" tractors and ALL have final reductions. Ford 9xx series row crop tractors are quite common.
True high crop versions are quite rare and do not have 28" rear rims/tires.
Dean
It's probably a row crop and not a high crop. The high crop had 38 inch tires.
At any rate, the bushings are the same as the 801 series.
The rear tires are 38'' and adjustable rims,it's a hi clear 900 from all the info i can get,thanks for all the info.
(quoted from post at 16:00:07 05/09/09) I have a ford 950 w/ adjustable wide front end and i need spindle bushings for the front end both sides.Are they the same as the 900?Thanks
I would go to the CNH web/parts site and look'em up,,, I use ONLY CNH spindle bushings when I can get'em,,, most of the time they fit with no reaming required
