3cyl 2000 - hourmeter stopped
Hogleg
Any way to rebuild? Worked for the first 80 hours I owned it but now stopped. Tach is still working correctly. Would like to get it working since the hours on the tractor seem to be correct (5351) instead of replacing. Motor was rebuilt around 5200 hours...
Check that the cable is fully seated in the hub. Sometimes it's just as simple as not being properly engaged...
I've seen the tach work and the proofmeter NOT work.
Rod
