Well guys shes got a bad leak now. As I was digging this morning I look down and I see a steady steam pissing out from the lower area of the backhoe mount. So I finish up with it and park it and look for blown hoses. I cant determine where its coming from. Theres fluid everywhere,.. Only thing is, everything works fine and is only barely dripping when I'm down there looking at it. I carefully tried everything while looking under there but cant determine exactly what was failing. So I need some recomendations as how to pinpoint what to replace. Next I'm going to remove the hoe to fix whatever it is. So my plan to remove hoe is stretch hoe all the way out flat. Lower outriggers onto pads and just barely take some weight off. Loosen to big nuts that hold rods that tie backhoe onto mounts and move rods out of the way. Use outriggers to lift hoe frame above hooks that that hold it. Drive tractor 4 inches forward and chock wheels and turn off. Undo 3 hydraulic lines that run hoe. Hopefully attach to smaller hoses together because they are positive pressure? Plug up end of bigger hose with something? Dive tractor away and park. Cut big piece of pine to right size to put block under hoe frame so that I can relive pressure from stabilizers and not get killed while working on hoe.
How can I find leak and hows my plan sound? Thanks so much for any help
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
