3 point ladder support
A previous post asked for dimensions for building a 3 point boom pole. This got me to wondering if anyone has ever built, or bought a rig that would allow the 3 point to support an extension ladder. I've thought about making one but can't quite figure out how to keep it from being a man killer.
(quoted from post at 12:32:04 03/22/09) A previous post asked for dimensions for building a 3 point boom pole. This got me to wondering if anyone has ever built, or bought a rig that would allow the 3 point to support an extension ladder. I've thought about making one but can't quite figure out how to keep it from being a man killer.
Now why is it that you might think you want such a rig?
I've seen both of those pictures before which is why I said "IF" it could be made, and not be a man killer. :lol: I have a 4"x4"x 24' steel post with a light on top. It's set in concrete, but kind of scary putting a ladder up against it.
Ok with no operator I have to assume this is a one man job and he climbed up the loader to the bucket. That may be streaching it a little.
When you guys look at these you got to remember I am from a era where I have had mens lives in my finger tips because they were rideing a headache ball hundreds of feet in the air on a crane I was operating.
John
The safety men/women of today would have a fit if they saw this!
Only one man to a ladder, it must be securely tied off, you are not permitted to work from a ladder, your belt buckle is not supposed to be outside the ladder, just to name a few!
Brian
Any time you deal with hyds. they can and will do funny things and get people hurt. Just think what would happen is a hose broke, down would come people and ladder etc
Old, You're right. I wouldn't want to stake life and limb on an old hose, or a fifty year old Hydraulic system. I was thinking along the lines of using the 3 point as a means of supporting the ladder, not to raise it. A better approach might be a boom mounted on the rear axle, hanging over the front end, with supports down to the front axle. A cross bar below the apex could be used to lean the ladder against, and a 4x4 in front of the front wheels would keep the ladder's feet from sliding back. Just brainstorming.
(quoted from post at 15:26:39 03/22/09) Old, You're right. I wouldn't want to stake life and limb on an old hose, or a fifty year old Hydraulic system. I was thinking along the lines of using the 3 point as a means of supporting the ladder, not to raise it. A better approach might be a boom mounted on the rear axle, hanging over the front end, with supports down to the front axle. A cross bar below the apex could be used to lean the ladder against, and a 4x4 in front of the front wheels would keep the ladder's feet from sliding back. Just brainstorming.
Or you could build my rig & just let the wife hoist you up in a harness or big bucket. :roll:
BTDT
JMOR
With a sheave mounted in the top, and a hydraulic winch installed to do the lifting, it would make an excellent lift mechanism.
For personal use, would it have to be inspected and inspection records maintained?
Brian
I think a rear mounted rig would flip my little 640 Ford, but your heavy Farmall is doing the job. Is that a Super M D? I spent many an hour on one of those as a 14 year old. It gave me my first experience at replacing a clutch.
(quoted from post at 15:54:25 03/22/09) I think a rear mounted rig would flip my little 640 Ford, but your heavy Farmall is doing the job. Is that a Super M D? I spent many an hour on one of those as a 14 year old. It gave me my first experience at replacing a clutch.
ou willl notice that I have some iron bolted to the front plow mounts, sticking forward of radiator, with a stack of iron & timber for front weight.........only needed it for 1st 2-truss assembly, put the remainder up one at a time.
SMTA, 1954.
Inspection? This was in the country. Most things are legal, and the other things are too unless you get caught. :twisted:
Awlknottedup
You will need a lot of weight on the front to lift much with that, due to it being so far back.
Brian
I don't know about the ladder. It might work pretty well actually.
I've thought many times about building a 3 point deer stand. A 16' tripod that you can pick up and move around. Leave it attached to the tractor for stability. And leave the tractor in the field for a month before the season so the deer are used to it. Move it around now and then.
Dave, I don't know what you need the ladder for but maybe a tripod would work.
Jmor, that's a great looking piece of rigging.
As for using your loader in different ways, around here we do that kind of stuff as often as we need to.
(quoted from post at 21:53:00 03/22/09) I don't know about the ladder. It might work pretty well actually.
<img src="http://i61.photobucket.com/albums/h56/Ultradog/one%20armed%20loader/P3190022.jpg">
Thank you! I was proud of it. I cut 54 of those tubes (pipe) out of a boiler to build the gin pole rig & my 32X48 hay shed, good for 108 round bales. Cut the shell in half on long side & used each half as a big culvert across two creeks.
Dang.. that looks familiar.. standing on something being held by a 1-arm loader...
BTDT many times!
soundguy
Thanks to all the replies, I now have some great ideas to run with. It just goes to show how a pipe dream can be refined when it's handed to a group of experienced folks.
JMOR, I really like your set up, and will be looking for a boiler to tear apart. Those tubes are bound to be made from some pretty strong stuff, and have to be lighter than the drill stems I've used on some projects.
Brian Allen, the winch will definitely be part of the project, but my hand cranked geared job will have to do for now.
Ultradog MN, Kind of hard getting up there to change the bulb.
Dave & Awlknottedup
I would like to see pictures of your versions when you are done.
That boom Awlknottedup posted looks like a usable item, but I won't have a category two tractor until I get the 4600 rebuilt. I think there is a valid reason for not using them on a category one tractor.
Keep me posted!
Regards
Brian
Brian Allen, Sorry for not responding sooner. I made a little trip to Tahoe to catch the last snow. I'll post pics when I come up with a workable rig.
Dave in MS
I will be happy to see your pictures whenever you are done, - don't rush on my account!
I will probably make one when I retire, (early 2011).
It would be great for lifting mounted on the 4600.
Brian
