AlanBarrett
The gauge cluster is new (aftermarket). I bought a Ford cable and installed. Within an hour, the tach stopped. I removed the cluster and unscrewed the cable from the rear of the cluster. The cable was a loose-wire mess.
Question is:
Isn't a 3000 tach cable wound backwards from a 3600 cable? That's the only thing I could come up with. I am just assuming I got the wrong cable. A 3000 runs clockwise and a 3600 runs counter, right? That would explain the cable unwinding.
Does it matter which end goes where?
Question is:
