I think you guys answered this clear back in "04" with a photobucket from John in LA (thanks for all the hard work.) As usual, someone has left me with a little different twist. They installed a standard (spring loaded) four position ignition switch, "ACC~OFF~ON~Start.
Yep, they left off the saftey wire. Yep, it"s a Select-A-Matic. Won"t go into the "Rest Of The Story". Stopped working on it, showered and went to work and still have not had time to return to it yet. I figure from all of the drawings you gentlemen put in here, that starter relay still has to have a ground wire. Will that saftey wire work, since it goes to ground when in park? Thanks!
