AlanBarrett
'74 3000 diesel w/ CAV pump.
New fuel filters
New fuel lines
New fuel tank
New air filter w/ correct amount of oil
New 2.0 battery cables
New battery
Engine will not start without a tiny shot of ether. Engine puffs gray-whitish smoke when turning over (before giving it a shot of ether).
Once started- will restart without ether.
When started cold- engine misses a bit but clears up after a couple of minutes. I started the engine cold and broke each injector line a bit. I think I noticed the sound didn't change much on #1 as it did on #2 and #3 when I broke the lines loose.
My brother-in-law thinks the problem is injector timing. I don't have a clue!
If I need a pump and injectors- is it cheaper to rebuild them? I live in north central Mississippi if anyone knows of a reputable business to do this.
New fuel filters
New fuel lines
New fuel tank
New battery
